M42 starter not engaging
  • Bimmer805
    • May 2012
    • 207
    i dont know what it is. its a m20 starter on my flywheel swap. what do i have to do now to make it engage onto the flywheel
    do i have to swap out the pinions on the starter?
    Luis
    Instagram: Bear_e30
    Getting the correct starter for the engine sounds like the right solution to me.
    • Bimmer805
      • May 2012
      • 207
      But it has a m20 flywheel so wouldn't the m20 starter be correct?
      Luis
      Instagram: Bear_e30
        The engine block & crank also affect what starter is needed. I see different part numbers on realoem.com. And that starter is only used on 318's with the M42 engine.
        • Bimmer805
          • May 2012
          • 207
          So I should just swap out the pinion teeth on the starters?
          Luis
          Instagram: Bear_e30
          • Bimmer805
            • May 2012
            • 207
            got it now it works like a charm
            Luis
            Instagram: Bear_e30
            • mr ilia
              • May 2011
              • 582
              what was the solution?
              This may help others.
              Thanks.
