Thump, thud sound from rear - only at take off, even low speeds.
    Ill double check that.
      i had the same issues and found that my Guibo was trashed after replacing it and still having the issue i had to replace my drive shaft due to bad U-Joints.
        HMMMMMMM --- got an update for you all.
        I lifted the car with a jack from the passenger side rear and heard a noise similar to what was going on. I checked the diff bolts and they were pretty tight already. So far, I havent had the issue since. WEIRD! I guess something just wasnt seated right.
          So I am still having the issue. Coming down to it - I think it is the U-joint.
            Mine is doing the same. It started clunking after a couple of burnouts. Hopefully its not the yoke thats messed up.
            1986 328 M50 stroker turbo, Precision 6262, Miller tuned, Aeromotive a1000, 8.5.1 Wiseco pistons, Eagle rods, Tial wastegate @20lbs, Tial bov.
            Instagram @e30_fred
