How do you know if used tranny is still good??
  • BMW***325
    • Aug 2012
    • 45
    Hey guys, I was planing on buying a used 325e five speed trans, but im not sure if the transmission is still good. Its all there, with aluminum shift console. How should I go about checking if its still in working condition and not shot, since its out of the car?????
  • bmwstudent
    • Sep 2011
    • 1364
    unless you can drive it there is no way to tell if the internals are in good shape. Sorry.
    • bmwguy325is
      • May 2011
      • 1263
      Look for leaky seals. U can check for shaft play (output/input)
      Bad seals could mean that level was ran low and smoked the layshaft.
      You can also check to see if the level is good.
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • K1CKBAC
        • 306
        When you say shaft play, you mean vertical/horizontal play or rotational play?
        My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
          • 37832
          How many threads are you going to start about a damn transmission?
          This isn't rocket science.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • BMW***325
            • Aug 2012
            • 45
            as many as I need to get my question answered @MR 325... my account says "noobie"
              The first response to your post has the answer. In the absence of obvious, visual, damage to a transmission the only way to know if it is good is to install it in a car and see how it behaves.
              • M-technik-3
                • 18946
                Oh man here it comes...
                • bubbajan21
                  • 1962
                  That would be 13 (so far) ;)
