Best Options for a Tight Shifter ??
  • porschelou
    • 135
    I will apologize up front since I'm sure this topic has been covered before - but I haven't found the Thread yet.
    We endurance race a 86 325e with a m30/3.5L ( 10-24hrs at a shot).
    I just installed a 3.91 LSD so we will be shifting more and into 5th for the first time. I need a tight / notchy gated feel for the shifter if that's possible.
    Please tell me what you have done out there -
    Our current setup is all factory with new bushings so on - they typical rebuild stuff - still not happy.
    So -
    I'm assuming we install a DSSR?
    I have also seen someone selling a Delrin bushing to replace the floating rubber mount at the rear of the upper part that bolts to the body - anyone try this? Will it bind up under load?
    Thanks
  • dannyyisntt
    • 3141
    I've also got an m30b35 swap.
    I'm running a bimmerworld body mounted race shifter
    Shortened AKG dssr
    Bimmerworld jaffister knob
    Can't beat it for notchy/gated shifting. there is ZERO play. It has the shortest throw of any car I've ever shifted. Plus it makes you feel like a race car driver.
    Quick warning tho for those that copy my setup. You are going to want poly or solid engine/trans mounts.
      The two best solutions I know of are the AutoSolutions race shaft or the AKG body mounted shifter. They are essentially identical in performance. Neither is a short shifter and that is a good thing as the greater throw lessens the chance of a miss shift.
