My dad recently purchased a 1989 325is, black on black, 155,000 miles. Lets just say, he spent too much on it.
Anyway, it had a major vibration issue from 2 grand up until 4 or 5. I knew right off the bat that it was the flex disc - looking under the car, that was confirmed. (chunks were missing).
Well, anyway, while I was down there, I did a couple of things:
- Rebuilt the linkage, used UUC shift carrier delrin bushings, and rebuilt all linkage except a new shift lever)
- Had a driveline place in town install a new center support bearing (after I seperated both halves of the driveshaft (marked both sides))
- Installed a new flex disc
- Removed the huge ass harmonic balancer
For one, this driveshaft was different - it had "headless" bolts - I had to pound them out - to remove the harmonic balancer. I thought nothing off it - since it wasn't needed. Come time to put everything back together, I pounded the headless bolts back in, and screwed the flex disc on.
I put everything back together, and all was well, however, there are some issues I didn't have with my car when I did the same work. To start with, the driveshaft makes a nice sqeaking noise depending on how fast I'm moving. It's only heard when the car is at a crawl - usually coasting down the driveway, or coasting in a parking lot. It's a constant, repetitive sound - it's not random. It gets faster or slower dependong on my speed. Eventually, once to get faster than a crawl, you no longer hear it.
The other thing is, the car still vibrates a little between 2 and 3 grand. It's mostly felt in 1st and 2nd gear. In 1st gear, when WOT, there's a fairly loud vibration felt for a split second at around 5500 rpm. Only at full throttle is it felt though.
Basically, my dad bought this car thinking he could fix the problems it has. So far, I've done all the work. And, since it's not my car, these issues piss me off even more than they would on my own car. he says he doesn't care, but I know he does.
Any insight on this?
Thanks!
Thanks!
