sloppy shifter
  • e34_spangler
    • Dec 2012
    • 314
    sloppy shifter
    well i picked up an 86' 325e yesterday coupe 5spd and the PO replaced the linkage and idk its just mad sloppy if you ask me are e30 just extremely sloppy or is there a way to fix this?
    Slop in the shifter is usually from worn shifter bushings. Replacing all the wear parts in the shifter would be the place to start.
    • e34_spangler
      • Dec 2012
      • 314
      ok thanks ill take a look at it tonight!
      • Cream
        • Jan 2008
        • 210
        the slop in the shifter is due to the plastic clips they use around the plastic shifter ball plus the shift linkage is only connected through one side of the shifter. T_____T like this, if you want to reduce the slop look at UUC's dssr and ssk, the slop bothers me as well but not enough to pay the big bucks on these.
        • e34_spangler
          • Dec 2012
          • 314
          Ok sweet thanks
          Sent from my SCH-I535 using Tapatalk 2
