squeaking like rubber on rubber coming from tranny area
  • richardkeith97
    • 1693
    so i thought my blower motor was bad again. turned it off and realized its actually a squeaking from my tranny. it only happens when im giving it gas. the driveshaft and guibo are not even a year old. ive never heard this noise before. its just like rubber squeaking at total random times during acceleration. any help is greatly appreciated and i plan on asking the place next to my work to look at it asap. just hope something worse doesnt happen until they can look at it. thanks again
  • richardkeith97
    • 1693
    also car runs and drives fine. no vibration or anything.
    • 997_rich
      • Feb 2013
      • 48
      manual or auto? happens in neutral or when in gear? clutch in or out?
      • richardkeith97
        • 1693
        its a manual. only happens when clutch is out and im giving it gas
        • richardkeith97
          • 1693
          its getting louder and louder and the squeaking noises are getting closer together. this morning it was hardly noticeable
          • richardkeith97
            • 1693
            if i take it easy its not as bad. bolts possibly loosened up? did guibo and driveshaft about a year ago
            • jim325
              • 228
              I would check the guibo. I replaced mine a few months ago(like 6) with an aftermarket one. The bolts started pulling thought the guibo. But mine made lots of noise and vibration. I put some new bolts and washers on to quiet and calm it down till my revshift guibo and center bearing show up.
              I might even get some ujoints and replace those aswell.
              If you bought a guibo from autozone or something like that I suggest getting a better quality one. I would atleast climb under the car with a flashlight and take a look at the guibo.
              89 325i: 86 535i motor+trans, JE forged pistons, MLS head gasket, ARP head studs, Comp turbo, GoodNTight b34 turbo manifold, e30.de motor mounts, AKG 75D engine/trans mounts, custom 3" exhaust, intercooler, MS2PNP, Megan Racing Coilovers.
              • richardkeith97
                • 1693
                all parts were from blunt ans driveshaft and support bearing were from portland driveline. all quality stuff
                • 997_rich
                  • Feb 2013
                  • 48
                  Clutch area? Throwout bearing? trans input shaft flexing and wearing on guide tube?
                  • richardkeith97
                    • 1693
                    getting looked at today at a bmw/mini place
                    will keep updated. im very curious what this new noise could be.
                    • richardkeith97
                      • 1693
                      center support bearing is junk. whatever portland driveline uses for parts are junk. the rubber around the edge is completely missing. i installed it in july
