Groan and vibration in rear of car
  • Skunkworks
    • Sep 2012
    • 436
    My wife's 325e auto has a condition that when driving it has a small vibration and a loud houl. Not pinion whine. But if you make a right hand turn it goes away completely. I replaced the left hand half shaft and it did not do any good. The surface had no indications of wear. And the old cv had no binding issues. Btw the driveshaft is good and the u joints are as we'll.
    Any ideas?
    My next task is to replace the other half shaft and the diff because I have them sitting on a shelf.
  • F34R
    sLaughter
    • 12390
    Sounds like the output shaft bearings. When you make a turn you put load on the bearing races.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
      The first thing I'd suspect with those symptoms would be a bad wheel bearing.
      • Skunkworks
        • Sep 2012
        • 436
        Jim I pulled it apart and it is loud very loud metal on metal ball bearing ish sound.
        Now to find it at a local parts house lol....
        • Skunkworks
          • Sep 2012
          • 436
          Found it at vatozone, I'm sure it will spin for about 20k miles before it starts to hum
          • Skunkworks
            • Sep 2012
            • 436
            Jim you hit it on the head, it could be a royal pain in the ass without the right tools.
