Clutch Switch pedal box & tranny swap help!
  • jwiles
    • Jun 2012
    • 200
    I am swapping out a tranny. the donor car did not have cruise control, but mines does since it was auto. the swaps going good but, but i cant seem to find the clutch switch or cruise control bracket that holds the clutch switch i know it should be on the pedal box but its not. What i am trying to figure out is what do i need to do, because on most cars the clutch switch has to be depressed via the clutch pedal in order to start the car. Do i need to track down a cruise control bracket and switch to continue with the swap, or will the car start up with out the switch and how should i go about the wiring if the switch is missing
    This is really throwing a banana:drink: into the whole thing.
    hell idk sometimes you just have to wing it. JW
  • Danny
    • 14216
    There is no clutch safety switch on an E30. The car will start without the clutch depressed.
    • jwiles
      • Jun 2012
      • 200
      okay, as far as cruise control goes will i need the switch and bracket still?
      Nice E30 by the way, i almost broke my neck to look at it,
        The connector for the clutch safety switch should be present, with a shorting connector installed.
        • jwiles
          • Jun 2012
          • 200
          Where would it be located or where should it be located in my case?
          since the pedals i have do not have one.
            The bracket for the switch is a part of the pedal box. The connector will be near the pedal box.
            • StereoInstaller1
              GAS
              • 22679
              Don't swap the whole box, just the pedals. Your clutches cruise kill switch bracket should be right there on your Auto car.
              Closing SOON!
              Thanks for 10 years of fun!
