Identifying dual/single mass
  • turnofftheradio
    • Apr 2005
    • 448
    So, while everything is apart, I figure I should replace the clutch.
    The car is an 85 eta, but... the engine has casting no. from '86, and I have no clue on the trans. I know neither are original. the car is frankinstein.
    Is there a way to visually tell which I have? or should I just pull the flywheel and weigh it?
  • Jordan
    • 12916
    One is a SINGLE MASS.
    The other is a DUAL MASS.
    https://mtechniqueabs.com/
    • e30Matt
      • 5077
      To clarify, you'll be able to easily which is which by looking at it. The single mass will be one piece of metal, the dual mass will obviously be more than that. Plus the dual mass will weigh in the neighborhood of 25-30 pounds, while the single mass will weigh more around 15-20.
      • turnofftheradio
        • Apr 2005
        • 448
        ok, I figured that both were a 1 piece design, just one was bigger. I have not seen any bmw flywheel besides my own. It would seem that I have a single mass. I think I'll weigh it too, just to be sure. thanks for the weights
        • turnofftheradio
          • Apr 2005
          • 448
          don't mass with me
