Tricks for getting those torx bits out in car
  • 96Formula6spd
    • Feb 2013
    • 96
    So in the middle of my transmission swap. Anyways trying to get access to the top bolts. Anybody got some special tricks to getting in there. I am almost willing to lift the motor out some. There has to be an easy way to get access to them.
    1987 325is- $700 project car
    1996 Pontiac Firebird Formula - Bolt ons,cam, 6 speed of fun.
    2001 Miata - Current DD and to be for sale soon.
    The Build- http://www.r3vlimited.com/board/showthread.php?t=281011
    Parts Car Part Out Left Overs- http://www.r3vlimited.com/board/show...21#post3860521
  • LJ851
    • 7919
    Torx bit, u-joint, enough extensions to get all the way below/behind the trans, long ratchet or breaker bar or impact.
    Lorin
    The M30 is God's engine.
      • 37833
      And drop the trans brace down if you haven't already.
      Grover Beach, California
      BimmerHeads.com
        Remove the transmission cross member and allow the rear of the transmission to drop. Then lift the front of the motor until the rear of the head is against the firewall. You'll have enough room then.
        Wobble extensions work much better than universal joints.
        • 96Formula6spd
          • Feb 2013
          • 96
          Yeah I may go get some wobble extensions. Having a friend come over to help. Transmission mount has been dropped. Going to try lifting the front of the engine up to see if I can get some more space. I knew this car was to easy when working on the motor. Had to be a hard part somewhere.
          • 96Formula6spd
            • Feb 2013
            • 96
            Well got the transmission out and in. After some light a good amount of extensions and a breaker bar got them all. Not to bad of a job once the transmission is dropped as low as it will go.
