Looking to finally do a E30 Manual Transmission conversion swap and I need your opinion on the NEW parts that should be replaced.
So far I have a complete swap available, but need to know if what parts should be replaced with new ones. While I am in there I want to replace as many parts to new ones if recommended!!!
I have seen many threads what explain the swap process but lack details on every single gasket and bushing I will need. I am still learning so I apologize if I missed this information in another thread.
Such as:
-slave cylinder
-master cylinder
-master cylinder reservoir
-engine mounts
-center carrier bearing??
-guibo
-gaskets?
-exhaust gaskets?
Someone elses parts list:
Conversion
-Master/Slave Cylinder*
-Reservoir to Master Hose*
-Master to Slave Hose*
-Manual Flywheel*
-Manual Driveshaft*
-Flywheel Bolts x 8
-Transmission*/Support*/Mounts*
-Pedal Box*
Shifter
-Carrier Arm*
-Selector Rod*
-Bitch Clip*
-Z3 Lever
-White Plastic Cup/O-rings/Spacers/Rubber Seal/Boot*/Knob*
Seals
-Shift Shaft
-Output Shaft (engine/tranny)
-Input Shaft (tranny)
Clutch
-Clutch
-Pressure Plate*
-Throw-Out Bearing
-Pilot Bearing
-Throw-Out Arm
-Pivot Pin
-Retaining Spring*
-Clutch Bolt x 6
-Pressure Plate Bolt* x 6
Such as:
-slave cylinder
-master cylinder
-engine mounts
-guibo
-gaskets?
-exhaust gaskets?
Conversion
-Manual Flywheel*
-Manual Driveshaft*
-Flywheel Bolts x 8
-Pedal Box*
Shifter
-Carrier Arm*
-Selector Rod*
-Bitch Clip*
-Z3 Lever
Seals
-Shift Shaft
Clutch
-Clutch
-Pressure Plate*
-Throw-Out Bearing
-Pilot Bearing
-Throw-Out Arm
-Pivot Pin
-Retaining Spring*
-Clutch Bolt x 6
