Fenco Clutch from Turner
  • dubtechnic
    • Aug 2012
    • 63
    So i ordered the used fenco clutch kit from turners warehouse/clearance section with clutch disc/pressure plate by fenco and sachs throw out bearing.
    http://www.turnermotorsport.com/p-11...clearance.aspx
    after ordering i started seeing some horror stories with fenco clutches, one in particular where the spring popped out of the clutch and destroyed a lot of stuff. did i mess up? should i return this and just go with OEM? im using this in my 5 speed swap car.
  • F34R
    sLaughter
    • 12376
    I always buy SACHS
    http://www.ebay.com/sch/i.html?_odkw...lutch&_sacat=0
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • bmwguy325is
      • May 2011
      • 1263
      I was raped by a guy named Fenco so yes Id be scarred of this clutch........
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • bmwstudent
        • Sep 2011
        • 1364
        Valeo makes decent stuff, go ahead and use it. Looks new, not used. It still has the printers ink on it telling you which way to install it.
