Sorry if this has been discussed before but I've searched and haven't been able to find the answer to my question.
Bought an E30 last September for the princely sum of $500. Needed some work (obviously) and I've been spending the intervening months trying to restore it's mechanical solidity.
One obvious problem has been the dreaded banging from down under. I bought a new center support bearing and flex disc when I ordered some other parts. When I put the thing up on stands and slid underneath, I found that the whole exhaust system is welded together, stem to stern. When I started to apply some torque to the bolts that hold that mess onto the exhaust manifold, the whole car started to move. Fearing for my life, I decided that this was one thing I would leave to my mechanic when I took the car in for inspection.
This morning, when I dropped the car off, I gave the shop the flex disc and CSB to install. This afternoon, I got a call from the shop. They told me they dropped the exhaust system, and then reinstalled it after examining the driveshaft. The mechanic told me he wasn't sure if I had the right CSB and there is no flex disc at all in the shaft.
At the front of the shaft, where I thought there would be a flex disc, the mechanic assures me that there is a u-joint similar to the one in the rear. All of the parts diagrams for my car that I have looked at, clearly show the flex disc at the front of the shaft.
The car is a 1986 325e sedan with a ZF 4HP22 automatic transmission. The car was built in June of '86. Is this driveshaft right, or has someone substituted the shaft from a Toyota Corolla or a Chevy Citation or some other piece of junk in my car's past?
I really hope that someone here can enlighten me about this. If this is some kind of updated shaft that I'm not aware of, would the CSB still be the same?
Thanks a million in advance for any answers you can provide!
