whats up guys i finished my first "big" project on my e30 with the big help of this forum which was replacing my flex disc and csb. sadly I ran into 2 hiccups I cant figure out 1) I can't get these rubber donuts back on to save my life, I even tried to jack the muffler up itself and I still cant do it any suggestions?
And 2) after I followed the pelican article to the T the car was still shaking (tested it on the jack stands before I let it down). At first I did some research and found it could be bad U-joints or tranny mounts, but looking under the car it was still shaking at the flex disc. I've retraced my steps and made sure I lined up the drive shaft properly by painting it, I put everything on right, only thing I could think of is my torque wrench is a little off. The gauge is busted just before the 40 lbs -___- but I torqued it very very close as in a little passed 40.
Anyways thanks again for any suggestions you guys are great. Also, I dont need too much help, mostly with these rubber donuts ill figure the flex disc thing out eventually just gotta tinker with it.
