drives in reverse only?
  • E30_pilot
    • Sep 2005
    • 1461
    Well. i found a 86 325e.
    The seller says it drives in reverse only. Any Ideason whats the problem, and how to fix it?
    -Frank
    1987 325is m50nv (schwarz)
    1990 325is (sterling silber)(sold)
    2001 525i
  • MrK
    • Jan 2006
    • 709
    Just a shot in the dark, but I'd assume the car is an auto, and the trans is screwed, allowing you only to engage reverse.
    This is your M20 on steroids:
    • Jordan
      • 12913
      if its a 5spd it may be a badly wasted flex disc. I've seen this disable cars going forward, but shit "catches" on itself to move backwards.
      https://mtechniqueabs.com/
      • Jordan
        • 12913
        Could also be a wasted 5spd. When I first got my car on the road I killed the tranny slamming it into 3rd with monsterous force against its will. (too fast)
        I broke off 2 shift forks inside the case. I lost all forward gears, and could only get into reverse.
        • bimmer8604
          • 3017
          If its an auto, its probably related to the valve body, which means $$$ to get that fixed, but there are a few automagic transmissions forsale here on the forums for dirt cheap ~100 bucks or so.
          If its a 5 speed, sounds like maybe shifter linkage, or theres some bent forks or something not allowing the shifter to get it out of reverse. could have stripped a transferre gear or something, too.
          Its probably a pretty easy deal, or its going to be a bitch deal. If the price is right, do it, you can get a new transmission for under 200 bucks in most areas.
          And a flex disc in a 5speed? wow.
          Kyle
          1988 M3, 97 840, 99 XJ
          DILLIGAF
          • E30_pilot
            • Sep 2005
            • 1461
            so basicly just replace the tranny,regardless if it's auto or 5spd, and i'm set right?
            btw car is going for 700 obo and Jordan thats one hell of a story, you're crazy man haha
            -Frank
            2001 525i
            • 88325isboy
              • Mar 2004
              • 1058
              Forward clutch pack is out.
              '87 325 (Track Rat)
              '04 C5500 Wrecker (Work)
              '94 525i (Daily)
              '90 325i (R.I.P)
              H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
              • Alluvium
                • Feb 2006
                • 42
                im not a mechanic but ehres my input
                the teeth of the gears form 1st-5th, are cut at an angle like //// that
                the reverse gear is a straight forward normal gear cut with teeth like ||||||| that
                (that is also why reverse makes that whiring noise)
                so it is possable the forward gears are all fusked up... just my 2 cents
