Auto wont shift out of 1st, until all warmed or redlined
  • 325igringo
    • Jan 2006
    • 2
    Hey, this is my first post, so please bear with me. I did an auto to 5-speed swap, and I want to make sure my auto works before i sell it to someone.
    When the car is cold in the morning, I have to let the auto in drive, and sit there for awhile with the engine running so that it could warm up. It will shift fine if I do that every morning.
    Or, I can drive with the car in first but it wont shift out of 1st for about a half mile, but then it will shift fine.
    Or, I can be a complete jackass and rev the engine to redline when the engine is completely cold, but the tranny will shift when it hits redline.
    Regardless of what I do, it will shift totally fine after the initial shift into first.
    I have read the other threads, and it seems that I should check/change the ATF, or that some valve could be crap. Is all I should have to do? I appreciate any suggestions! Thanks, and sorry for the long-winded-ness.
    -Andrew
    I really need to make a new signature.
  • T.Dot E30
    • Mar 2004
    • 536
    The first thing I would do is change the ATF and filter.
    That usually solves most problems unless its too late. If it still does it, there is not much you can do but rebuild it.
    • NC325iC
      • Mar 2004
      • 6565
      or swappy swap
      • 325igringo
        • Jan 2006
        • 2
        So I should start out by changing the atf? And what filtter is that? I have absolutely no knowledge of automatics. in fact, I hate them. Thats why I already did the swap. i'm trying to make sure my old one works.Thanks for the replies, that was quick!
        • James Crivellone
          Head Janitor
          • 6304
          When I had an auto in my car, it did that to me once after it was REALLY cold one night, just straight to redline without shift.
          I let it idle in P for a few min and it fixed itself, never came back until I ripped the bastard out.
          • 92 mtechnic cabrio
            • 4907
            The Bentley Manual states that a majority of the automatic's shifting and drivability problems can be solved with a simple fluid flush and filter change.
            R.I.P 07/01/09 - 04/23/10 :(
