Question about transmission fluid use.
  • 92 mtechnic cabrio
    • 4907
    These had 17mm EXTERNAL wrenching oil plugs. If the label is green, use Redline MT90. If the label is red, use Redline D4 ATF. If there was no label, the gearbox will have 17mm INTERNAL wrench oil plugs, and should use Redline MTL GL-4 70W-80.
    My tranny has no label, but I used MT90 anyways, am I going to be having any problems? I really don't feel like draining it and pouring out all that $10 (or however much) I spent on tranny fluid.
    Thanks
    R.I.P 07/01/09 - 04/23/10 :(
  • T.Dot E30
    • Mar 2004
    • 536
    isn't it 75w-90 for the internal 17mm drainplug?
    thats what i used.
      • 4907
      thats what i used.
      That is correct. But I filled it with MT90 before I read about all this.
      • AdamF 88iS
        • 2051
        It will be ok. I actually don't like 75-90 redline in trannys, and it even says on the bottle not to use it in trannys.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • Beej '86 325es
          • 2639
          I just use the Redline MTL in mine. Is does the 75-90 work better in our transmissions or something? No one else seems to use the MTL.
          -Brandon
          '86 325es S50
          '12 VW GTI Autobahn DSG
          '03 540i M-Sport (sold)
          '08 Jeep SRT-8 (sold)
          For sale:
          S50 TMS chip for Schricks
          • e30 gangsta
            • 3877
            mtl right here no problems @ all.
            • Schneider325
              • May 2004
              • 3818
              I found a red label on mine today. Turner says that the ATF should be used in transmissions produced after 1/95. Can anyone explain why I should be using ATF in my manuel transmission?
              Thanks
              Jon
              • e30 gangsta
                • 3877
                no idea but im thinking of dropping mt90 in mine.
                  How about because that is what it is supposed to have in it. I'm not positive, but I think all BMW manual transmissions since the mid eighties use ATF as fluid. I know that the Getrag as found in E30's does.
                  • AdamF 88iS
                    • 2051
                    They phased it in from the late eighties until the 90s where they most all use it now.
                    Adam Fogg- '88 M3
                    • tonytony
                      Knee deep in poopie
                      • Jan 2004
                      • 3498
                      ok so i think i just bought the wrong fluid. I just bought ATF for my 91 g260, it has internal 17mm drain/fill plug. Will the ATF work or should i return it and get MTL instead?
