Driveshaft removal issues
  • cgk_iii
    • Dec 2012
    • 616
    Hey so im in the process of removing the deiveshaft. However i came to realization that the passenger side parking brake shoe is off. The drive shaft keeps on spinning when i try and loosen the bolts. I managed to get 3 bolts out with enough liquid wrench but the rest are on there tight and the driveshaft won't stay still. Any suggestions on how to keep the driveshaft from turning? Other than replacing the shoe?
  • bastianshaw
    • Jan 2007
    • 2210
    puuuuuut the car in gear?
    • golde30
      • 11464
      Have some1 step on the brake pedal.
      IG: @Baye30
      • cgk_iii
        • Dec 2012
        • 616
        Tried that too didnt work..
        • cgk_iii
          • Dec 2012
          • 616
          I tried wedging a piece of wood to hold down the brake but it may have not been enough force. Ill give that a try with my pops
          • DIIRTY-30
            • 1665
            If anyone has an answer to this; greatly appreciated...
            Background : Removed driveshaft, U joints are toast, Buying a new driveshaft.
            Q - When re-installing the new driveshaft, I know you mark the old one's position when removing from the trans. How do you know which flange is supposed to line up with the old one when installing a NEW driveshaft? Is there a specific flange to flange or am I shit out of luck and have to guess?
            Thanks for the input in advance.
            BLUE NOSE - M62 SWAP
            THE E30 + 1 BUILD
              It doesn't matter how the ends of the drive shaft are mated to their respective flange. It does matter that the drive shaft halves are aligned per the paint mark.
              • DIIRTY-30
                • 1665
                That's what I was hoping to hear! Thank you!
                THE E30 + 1 BUILD
