So I have problems shifting into first and starting on my g260. sometimes i will shift in and then pop out once i start letting the clutch out. When the car is cold it works fine even if i drop the clutch, but once the car is driven a little and warms up, it starts having issues again. Also the shifts are a little rough. At first i thought it was my slave or master, but i replaced both. Now Im wondering if its maybe time to change the tranny fluid. Any thoughts?
Tranny Problems
so i checked the fluid level in the tranny. i was shocked. there was less the half a quart. there needs to be 2 right? so i bought redline mt 90 ( thats what i heard was the best ) and i bought valvoline 85w140 gl5 for my diff and limited slip additive. is this all the right stuff?Comment
ok. so update. got underneath my vert today. put in new tranny fluid (redline mt90) and not only does first gear work but every gear shifts like butter. so happy:). then i went to change my diff oil and noticed that i had a 2.93lsd. wth? good thing i checked now. supposed to come with a 4.10lsd. i went to check what i had in my parts car vert and it had a 3.73lsd. so i swapped the diff today and man do i feel a huge difference in power. i think i will be satisfied with this one for a while. never knew changing fluid had such a huge difference on the tranny.Comment
my rusty bitch had an orgasm when i filled her up good with MT90 hahaComment
