3.46 lsd
  • polska
    • 19
    3.46 lsd
    I can find the 3.46 open all day, but having a tough time finding a 3.46 lsd.
    Anybody know exactly which cars those came on?
    This is for an e30 swap. Thanks.
  • LJ851
    • 7919
    e28 535is automatic, there are some in e23 as well.
    Lorin
    The M30 is God's engine.
    • polska
      • 19
      For guys like me, who need clarification on the terms, I just wanted to add some info.:
      When i'm looking for a limited slip, I came across "non-posi", which I didn't know.
      Which basically means it's an open diff.
      The name "posi" originally was used by GM as the brand name for its original equipment limited-slip differential. The full name was "Posi-Trac." After a time, "posi" became a popular name for limited-slip differentials of any origin.
      • thebutterson
        • 463
        I have a small case 3.45 if you're interested.
        • e30rapidic
          • 2167
          my 3.46 LSD came from a 635csi
          '87 325ic, powered by S50.
          • Wanganstyle
            • 2828
            go to your local dismantler and find a Z3 6 cylinder unit; they are common in 346 323 315 307. shove right into a e30 6 cylinder unit place; its the same casting by BMW from e23(1982)-e36/7(2003)
