I'm driving along in 3rd gear at normal speeds when I make an easy shift to 4th. The car revs high and I think "I missed the gear". I try again, and the same thing happens but this time I can feel it catch before it breaks loose. I proceed to nurse it a few more miles, but anything past 1/16 throttle breaks it loose.
Of note:
Clutch pedal feels normal
Shifter feels normal
All gears are selectable and do in fact change the gear ratio
I have fluid in the reservoir
Clutch is only a year old, and was very strong just before it went out.
So where do I look first, and what are the chances this gets even worse? I'm going to try and nurse it a few miles home tonight after traffic dies down, hopefully it'll be okay.
But I'm baffled. Google searches show lots of brokens trans, shafts, and diffs, but that cant be it. I know a half dozen things that'll keep it from DISengaging, but to keep it from engaging fully? Shattered clutch disc? Rear seal blow out violently and sprayed oil over anything? Nothing was dramatically dripping by the time I parked it on the side if the road.
Anyway, if I make it home to iffy I'll report what I find. I guess if nothing stands out I pull the trans...god I hate doing that...
Of note:
DREWLIENTE
