So When I bought my car it was at 142xxx miles and the transmission whined REALLY loud. One night I was driving down my street and it sounded like the damn thing was growling at me. I filled it up with transmission fluid, Don't know what kind at the moment. That definitely quit it down significantly but now at 149xxx miles it is whining pretty loud and I have found no leaks! Is this how all E30 transmissions are? My dads IX is nowhere near the same.
Whine whine whine
Tags: None
1991 325i Calypso Coupe
Like Grandfather, Like Father, Like Son
BMW
I had the same problem. Bought the car with a trans whine, turns out the trans was dry. Refilled and it went away but slowly came back. Discovered my output shaft seal was leaking but only when the car was moving.
Check your fluid levels again. If it's low again the fluid is going SOMEWHERE.Comment
Does it whine in every gear but 4th?Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
