drive shaft problems!
  • chos2k
    • Aug 2013
    • 4
    Hello all,
    just recently purchased my 1987 325e.
    car is in fairly good condition but one slight problem!
    i think there is an issue with the drive shaft. It vibrates a little and clunks a little in first gear, and somewhat 2nd. I have heard this might be either due to the guibo, center support bearing, or the u joints (?).
    I have taken off the exhaust off the car and the first heat shield. but i am wondering how to continue to further examine my drive shaft.
    i have seen diys.. but to really check whats wrong i'm wondering what i need to do. soemone mentioned buying a whole new driveshaft that has been already balance and etc etc...
    wondering if thats the best (or better yet the easiest) solution for me. i checked the guibo and it seems the front (towards the transmission) seems to be wearing out a bit, but doesn't seem to be torn or such (just rubber being old). have yet to remove the cat/header (if anyone can explain if i need to disassemble the whole header/cat system is necessary that'd be awesome :D).
    lmk what I should do and what would be my best bet!
    thanks all!
  • e34_spangler
    • Dec 2012
    • 314
    Yeah u joints cause clunking which will mess up the bearing when the bearings going bad (vibration) you should replace it with a bad guibo your driveshaft could come up through the floorboars
    • chos2k
      • Aug 2013
      • 4
      so replace the whole driveshaft??
      what do you mean by "with a bad guibo?"
      so i should just swap out the csb/guibo/ujoints while i'm at it?? what is the exact location of the u joints on the car? any links to good diys... thanks!
      • e34_spangler
        • Dec 2012
        • 314
        Well I had my guibo done cause yah your driveshaft will come through the floor board it holds the shaft and yeah I was told by a. Uddy when its vibrsting time for replacement mine just clunks so I'm waiting for the vibrating:p
          A vibration the seems the come from under the car that is worse in lowest gears when accelerating briskly is usually binding u-joints in the drive shaft and a failing CSB. Replacing the CSB may provide temporary relief but long term fix is a new or rebuilt drive shaft. Clunks when changing gears could be from worn u-joints in the drive shaft, but more commonly they will be from wear in the differential or something loose in the rear suspension.
          • chos2k
            • Aug 2013
            • 4
            awesome.
            i will look into replacing the csb... possibly not. I might just wait til it dies. prob can give out another 20~30k miles hopefully :D :D :D :D :hitler:
            then do a full swap... might be worth it more in the end maybe. :) thanks for the insight all
            • Cephas
              • Apr 2012
              • 878
              I had some wicked vibration in 1st and 2nd gear under full throttle from the center of the car. U joints were binding so I replaced the drive shaft. Not cheap, but it should be 24 years till I need another.
              • Poorboyz
                • May 2012
                • 2117
                I had same problem and my CSB was completely gone. I replaced it right away and all vibration went away...now I think my rear wheel bearings are humming...lol
                Sent from my Galaxy Nexus using Tapatalk 4
                Rebuilding since 07/06/2016
                Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                Poorboyz Feedback Thread
