Help on buying a clutch.
  • burlmays9
    • 227
    I have a NVM50 with a ZF trans... Engine and trans came out of an E34 but I think all the model designations recognize the E34 having a G250.
    So for what model car should I be getting the clutch for?
    Also looking to get a six-puck clutch. Suggestions and or hookups are much appreciated.
  • golde30
    • 11464
    you need to find out which size flywheel you have, its probably the 228mm flywheel if early m50.
    IG: @Baye30
      • 37834
      Match the clutch to the flywheel.
      In other words if you're using a M50 flywheel, use a M50 clutch.
      Grover Beach, California
      BimmerHeads.com
      • burlmays9
        • 227
        The E34 the motor and trans came out of was a 92 so it's definitely an early M50
        • burlmays9
          • 227
          Also are the splines on the input shaft different between the G250 and ZF trans?
