transmission mount
  • mathillois
    • Sep 2012
    • 71
    transmission mount
    hey r3vers,
    i have an 89 325i in need of new transmission mounts. ive looked on forums and online stores to see whats available. to what i have found online for street/track mounts are the uuc, e21 mounts, and vorshlag 80a mounts. ive heard some negative reviews on the uuc's and nothing about the e21 or vorshlags. so my question: which to get??? i know with the e21 mount i need to drill a slightly bigger hole which isn't a problem, im just looking for quality and whats best for the street/track scenery. let me know and thanks in advance.
    -marc
  • mathillois
    • Sep 2012
    • 71
    Anyone???
    • Restoman
      • Jun 2006
      • 1311
      I've heard condor speed shop has good delrin stuff. Blunttech sell for them, also a site sponsor.
      i'lldoitforacaravan
        • 37834
        Stock.
        Grover Beach, California
        BimmerHeads.com
        • mathillois
          • Sep 2012
          • 71
          ill check that out. would stock be the best option??? compared to uuc or delrin or vorshlag or e21 mounts?
          • mathillois
            • Sep 2012
            • 71
            those are recommended for race only. i mostly drive my car on the street and occasionally do track and drift. any input on the ones i listed? those are the ones i found to be street/track
            • meengreene30
              • Mar 2012
              • 369
              Originally posted by MR 325
              Stock.
              ^this. e36 oem mounts are a good choice. No NVH.
              • mathillois
                • Sep 2012
                • 71
                so e21 vs e36 mounts, e36 win? even if e21 mounts have a wider stud?
                • meengreene30
                  • Mar 2012
                  • 369
                  I've never used e21 mounts but i'm more than happy with the e36 ones. Perfect combo with condors motor mounts. My condor trans mts came off in 2 days, too hellish for me.
                  • mathillois
                    • Sep 2012
                    • 71
                    how do u like the condor motor mounts? do u use it strickly for track or for street to? any vibration or noise?
                    • mathillois
                      • Sep 2012
                      • 71
                      still havent heard any input on the e21 mounts
                      • meengreene30
                        • Mar 2012
                        • 369
                        the motor mounts are great. this car is my daily but i'm not gentile with her. no vibration/noise.
                          AKG or Powerflex make very good poly mounts. For a dual use car, use those of 75 durometer rather than 90 for reduced NVH.
                          • Wanganstyle
                            • 2828
                            for street use the E46M3 stock mounts are a direct interchange with the original e30 mounts; uses same hardware. e21 uses different size stud and needs modification/
                            e46m3 transmission mounts are interchange fit for e36 m3 also.
                            even for HPDE track use the e46m3 stock mounts are quite good - if your car is caged then stiff poly/delrin or solid metal mounts would be ideal.
