Won't go into gear!
  • OOMPH!
    • 3487
    Won't go into gear!
    1989 325is M20, 5spd.
    I haven't drove my car for awhile. Today I started it and it refuses to go into gear. I checked the clutch reservoir and it has fluid. The clutch itself feels soft. If the car is turned off I can put the car into gear but not when it's running. Any ideas?
    Thanks
  • jalopi
    • 2370
    The clutch hydraulics are probably shot. Jack the car up and have a friend pump the pedal - see if the clutch fork moves. If not, maybe bleeding it will temporarily help...
    • AndrewBird
      The Mad Scientist
      • 11897
      Either your clutch master cylinder or clutch slave cylinder has died. Check for leaks under the dash and under the car from the side of the transmission.
      • OOMPH!
        • 3487
        Thanks guys! Yes I'm having both the clutch master and slave cylinder replaced.
        • NJ2.5rser
          • May 2013
          • 527
          What did this turn out to be. Just had the same issue and swapping slaves in a couple mins. Then if necessary will swap master cylinder.
