Whiny b!tch
  • ParsedOut
    • Sep 2005
    • 1437
    Whiny b!tch
    Just picked up an 87 325e and above 35mph there is a pretty high pitched whine coming from the rear (it seems). It's speed related. The driveshaft feels good, no vibrations. I've had CSBs go out on me in the past they usually rattle and vibrate.
    I've noticed generally when bearings go out they get loud and "ROARY" instead of whiny. This noise sounds very much like a gear whine.
    Has anyone noticed a rear wheel bearing, half shaft, CSB make a whine instead of rumble? So any idea what I should be focusing on here? Rear diff seems to be the mostly likely culprit.
  • series88
    • Nov 2011
    • 1231
    I vote diff. :)
    • andrewm
      • 456
      Diff.
      1987 Delphin 325e Sedan - Natalie
      1990 325i 24v
      1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
      • ParsedOut
        • Sep 2005
        • 1437
        Hmm... well time to find a 2.93 laying around.
        Thanks guys.
          Differential or wheel bearing. Until diagnosed either is equally likely.
          • e30saam
            • Jul 2012
            • 359
            Try and find a 3.25 diff from an e28, just replace the diff cover with an e30 one, this will wake your eta up. They are the perfect diff ratio for etas.
            • ParsedOut
              • Sep 2005
              • 1437
              I've never had a wheel bearing make a whine, usually they growl. Have you experienced otherwise? Other than just replacing parts, what would be the best way to diagnose?
              I spend 90% of my time on the freeway commuting, although a slightly shorter gear ratio sounds nice. :)
              • e30saam
                • Jul 2012
                • 359
                Yeah I drove a buddies eta with a 3.25, it was a lot of fun around town though. But my eta with a 2.79 LSD revs a bit lower on the highway.
                • ikonwun
                  • Apr 2012
                  • 374
                  PM.d you man. sorry to hear that this one is taking a lot of work too.
                  oh yah it sounds like a rear diff.
