How big is the transmission circuit in the radiator?
  • Ether-D
    • Sep 2011
    • 2838
    In a m20b25 e30 auto, the radiator has 2 extra bungs for transmission cooling lines. How much of the radiator does this use? Does it have lower engine coolant capacity than the 5-speed version because of this?
    I run a 5-speed, but I have a rad from an auto in the shop, and I thought I might be able to use that second radiator circuit to cool something. If I ever obtained something that needed to be cooled, that is.
    Thanks in advance for your helps.
    Jacob
    Originally posted by Andy.B
    I was born on 3/25…
  • Ether-D
    • Sep 2011
    • 2838
    I guess no one knows. After examining mine for a bit, it seems to be very small and perhaps only built into the one side, not even using the main fins. It could do a very small job if needed. Not the one I'm hiring for.
    I was born on 3/25…
