87 325e No Flex Disc...Uncommon?
  • greentalks43
    • Nov 2011
    • 39
    I was supposed to replace the driveshaft on an 87 325e and it had no flex disc. Infact the front of the driveshaft had the same 4 bolt setup as the rear section that bolts to the diff. I've searched high and low online with no results or part numbers. Can anyone help?
  • Killacortes
    • 1937
    It is uncommon. My 86 325es has no guibo either. If you do replace the ds with one that has a guibo you can pull that 4 bolt output flange off the tranny
    r3v does not fuck around. First you get banned, then they shoot you
      • 37834
      I've only seen this on some automatic cars.
      Grover Beach, California
      BimmerHeads.com
