4.10 How can I tell by Teeth or Rotation?
  • GT BMW E30
    • Nov 2008
    • 2491
    I am looking for the thread or post explaining how to count the teeth and rotation to tell if you have a 4.10 diff or not. Diff has surface rust on top and bottom. No stamp, no tag. Car comes with a 4.10. I want to confirm it.
  • LJ851
    • 7919
    4.10 is the ratio. If lsd, measure how many rotations of the input it takes to turn the outputs 1 rev.
    If non lsd (open), hold one output stationary and measure how many rotations of the input it takes to turn the other output 1 rev.
    Lorin
    The M30 is God's engine.
    • Wanganstyle
      • 2828
      Pull cover if its out.
      The ring gear of a 188mm 4,10 ratio gearset is stamped "h21"
      Sent from my SAMSUNG-SGH-I337 using Tapatalk
      • GT BMW E30
        • Nov 2008
        • 2491
        great. going to check now.
        • cabriodster87
          • Jan 2011
          • 1042
          Count the teeth on the ring gear and pinion then divide. Example 45/11= 4.09
          Reich und Roll!
