no pressure on clutch
  • itskingsteelo
    • Jul 2013
    • 1340
    hows it going everyone,
    so heres the deal, ive had my e30 for some time now, recently my clutch master cylinder went out so i replaced it, now its not responding, not building pressure, the pedal just stays down. ive tried bleeding it and reverse bleeding from the slave cylinder bleeder screw. still nothing. there anything else i need to do?
    Originally posted by dvck
  • e30trooper
    • 11576
    is the slave bad?
    • itskingsteelo
      • Jul 2013
      • 1340
      Originally posted by e30trooper
      is the slave bad?
      nope
      • e30trooper
        • 11576
        Double check the lines and re-bleed
          Did you replace the master cylinder with a new BMW OE part? If not I'd suspect the MC.
          • itskingsteelo
            • Jul 2013
            • 1340
            thanks for the input guys, i switched the slave as well and reverse bled the line to get rid of all the bubbles now the pedal has the right amount of pressure. after i finished up with the master and slave cylinders i noticed that my pedal isn't coming up all the way like it should and its not going into gears. i had a buddy of mine who is a bmw mechanic take a look at it and told me that my pressure plate is bad so im just going to replace the entire clutch that way at least i can upgrade. any suggestions for a clutch?
