Does clutch look useable still??
  • Nick_S
    • Apr 2011
    • 3658
    This clutch disc is only about 9 months old. It was replaced when my TOB went out earlier this year. Upon re-installation somehow my input shaft seal was damaged and started leaking a little fluid. After a while this caused the clutch to slip. I never really drove it hard after it started as I was planning on a swap which I have since started (M50NV+G240). I'm going to reuse my M42 flywheel, pressure plate and hopefully this clutch. I cleaned it off with brake clean and a light wire brush. It looks fine to me but I am not by any means knowledgeable about clutches.
    Second question. Again, I know very little about clutches. Can I replace just the clutch disc and use my OE pressure plate as long as I use an OE clutch?
    Thanks,
    Nick
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
  • ttrousdell
    • Nov 2009
    • 1770
    doesnt look glazed or burnt. id use it
    The Build:
    • Nick_S
      • Apr 2011
      • 3658
      Cool, thats what I was thinking. Wanted a few second opinions.
      05 Honda Pilot
      24V swap thread
