Motor and tranny pulling question
  • blueapplesoda
    • Dec 2005
    • 1904
    I'm goin to pull my motor and my tranny. Am I able to pull the motor and tranny out at the same time(attached) thorugh the engine bay? Cause i am renting a jack and was wondering if i could do this cause it would make life easier.
  • Sean
    • 5793
    Yes, but you will need more than a jack - unless you're tlaking an engine hoist?
    If you have a hoist, you'll also need a load balancer, as you will need to tilt the tranny + the engine a pretty large amount to get them out together. f course - dont forget to disconnect the driveshaft, and other stuff connected to the tranny! ;)
    - Sean Hayes
    • Brew
      • 3060
      IMO, this is the only way to do it if you don't have a lift. You can make do without a load leveler, but it certainly makes things easier.
      '91 318is
      • Beej '86 325es
        • 2639
        I didn't use any kind of load balance or counterweight or anything. My hoist has long, fold-up legs on it though.
        Don't forget to disconnect (because I did):
        ground cable connected to oil pan on driver's side
        hydraulic clutch line
        reverse switch on passenger side of transmission (for manual)
        -Brandon
        '86 325es S50
        '12 VW GTI Autobahn DSG
        '03 540i M-Sport (sold)
        '08 Jeep SRT-8 (sold)
        For sale:
        S50 TMS chip for Schricks
        • blueapplesoda
          • Dec 2005
          • 1904
          yes, i have an engine hoist jack thing...i can rent that leveler for free...so its possible. Thanx for the advice.
