M3 adapter to run late shifter on early trans... A myth?
  • FLG
    • Sep 2011
    • 3165
    That sounds like a great idea!
    For the rest of us (at least me) if you get a few min, just see if that would in fact work. Just to settle this once and for all...ive done more research looking into this then i care to admit.
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • 37825
      I'll check it out this weekend!
      Classic BMW Specialists
      Santa Clarita, CA
      www.BimmerHeads.com
      • gath
        • 577
        We have a number of people on here who fab some nice products and I believe that making one to fit a g260 would not be all that hard. I for one would be a buyer if they are made, ;) and I think there are other people who are in the same predicament.
        • Roysneon
          • 4505
          Originally posted by MR 325
          I'm just going to make my own DTM style shifter with some help from Myster-E. ;)
          Next Bimmerheads product? Maybe one under $450
          Originally posted by mbonanni
          I am a pursit now.
          • kronus
            • Apr 2008
            • 13003
            You can make one pretty trivially out of a sheet metal console with a hacksaw and a sledgehammer..
            cars beep boop
            • Roysneon
              • 4505
              We have one of those at the house here, I still like the look of the AGK one with no shift boot because I'm a ricer.
              I am a pursit now.
                • 37825
                I'm going to use the original sheetmetal console as the base for it. Will cut it and bolt it to the floor.
                Santa Clarita, CA
                www.BimmerHeads.com
                • LJ851
                  • 7918
                  You are running solid (non rubber) engine/trans mounts right ?
                  Lorin
                  The M30 is God's engine.
                    • 37825
                    No. I would never run those in anything.
                    Santa Clarita, CA
                    www.BimmerHeads.com
                    • LJ851
                      • 7918
                      What do you think is going to happen when your engine/trans moves around on the rubber mounts with your shift carrier immovable being bolted solid to the floor?
                      Lorin
                        • 37825
                        I'm not too worried about it. A friend is running the same type of setup on his E30 which sees hard street AND off road use. He's on stock rubber mounts and has been running this way for about a year and a half.
                        Santa Clarita, CA
                        www.BimmerHeads.com
                        • kronus
                          • Apr 2008
                          • 13003
                          I have poly mounts and hard mounted shifter and haven't missed a shift yet...
                          cars beep boop
                          • LJ851
                            • 7918
                            I wouldn't be worried about poly mounts, they keep the power unit pretty rigid, the rubber mounts do not and that would put a lot of stress on the shifter mounts on the trans and also the shifter platform itself.
                            I'm not trying to change Matt's mind, just bringing the point up.
                            Lorin
                              • 37825
                              How will it put stress on the shifter mounts on the trans? I won't be using them.
                              Santa Clarita, CA
                              www.BimmerHeads.com
                              • LJ851
                                • 7918
                                LOL, i have been thinking about shitty 911 transmissions for too long, please disregard my previous concerns.
                                Lorin
