-Diff tag
  • SpecM
    • Oct 2005
    • 4531
    -Diff tag
    -Well, it reads: 4.10.9251
    -Surely I don't have a 4.10 diff! What else could this mean?
    1989 cirrisblau-metallic 325i
  • kencopperwheat
    King of Kegstands
    • 14396
    You're probably reading the wrong one. It's a small piece of flat metal that will have "X,XX" stamped into it. In Europe they use commas to separate numbers when we would use a period.
    Originally posted by Gruelius
    • SpecM
      • Oct 2005
      • 4531
      -I found the tag on the upper right-hand side, attached with on of the diff cover bolts. I accualy had to take it off and clean it good to read it.
      • Rigmaster
        • 3464
        Sounds like that's it.
        a 410 in a super eta car, that's gotta be alot of shifting, huh??
        Bret
        • 2002maniac
          • 4260
          Bret
          Yeah, I bet it hauls ass until he redlines 5th at 65mph ;)
          • SpecM
            • Oct 2005
            • 4531
            -Yeah, first gear is useless with 170 lb-ft and a 5400 rpm redline....
            -When I first test-drove it, I was so afraid of sloting the shfter into reverse I started, from a dead start, in third. It'll do it!
            -Baby tops out at 110mph, and it'll get there in a hurry.
            • SpecM
              • Oct 2005
              • 4531
              -Well, the motor turns about 3400 rpm at 70mph in fifth, and I've been informed (by e30matt) that I most likely have a 4.10 rear-end
