Other than the 700hp e30 m3. Its very tempting. I'm afraid that my zf trans will not hold up with the set up I got. But I may be wrong. I would like to see a few e30s with bmw motors with it.
Anyone with a TH400 gearbox?
1986 328 M50 stroker turbo, Precision 6262, Miller tuned, Aeromotive a1000, 8.5.1 Wiseco pistons, Eagle rods, Tial wastegate @20lbs, Tial bov.
Instagram @e30_fredTags: None -
good-n-tight had a custom adapter made for a ford c4. What kind of numbers are you thinking? I know of a few 600+hp cars that run the zf.sigpic
Instagram @rebellionforge -
I'm thinking numbers around 450-500 with the stock head and vanos. I will build it in the future and increase boost. Its set at 14 lb.1986 328 M50 stroker turbo, Precision 6262, Miller tuned, Aeromotive a1000, 8.5.1 Wiseco pistons, Eagle rods, Tial wastegate @20lbs, Tial bov.
Instagram @e30_fredComment
Instagram @rebellionforgeComment
Almost all turbo e36 guys still run the zf with very few problems. There are a couple running around locally that are pushing 600+ on the zf without issue. You should be fine.88 325is - S52 powered
Originally posted by King ArthurWe'll not risk another frontal assault, that rabbit's dynamite!Comment
