Just replaced auto trans no start
  • Skunkworks
    • Sep 2012
    • 436
    So I just replaced my auto trans with a rebuilt zf unit. Everything is assembled and I hit the key, nothing, I did need to rotate the motor by hand to get the converter bolted up, does the flange on the flywheel need to be in a certain postiion before starting for the cps to read it?
    I have already checked binding on the starter, it's good.
    One of the cps units looks to have a cracked connection at the wire connection, not at the sensor end. It still plugs in fine.
    The car is in park. It's not that.
    Battery voltage is good. Starter is good. I drove the car a week ago with no start issues...
  • SpecM
    • Oct 2005
    • 4531
    make sure the starter is wired correctly and the trans range switch is plugged in
    1989 cirrisblau-metallic 325i
