It's winter and I am finally getting around to this. When I'm in 4th gear my shifter will shake a good bit. But only when off the gas. Under acceleration or clutch in no shake. Also in 5th there is a sound of shaking but the shifter does not shake. I thought maybe the pita guibo Shield but I remembered I took that out. The CSB was just replaced like 600 miles ago. My u joints were fine, and guibo good too. I can see those being the problem, but I figured I would just add that. Haha. I daily drive this car so I can't really just take things apart. It's a 88 325i swap to manual but I didn't do the swap so I feel like anything could be wrong ( the head was under torqued when I got it. Rebuild head is only good if it will stay on the car. So the trans could be held in with one bolt for all I know... It's not). Thanks for any answers or advice.
Sent from my iPad using Tapatalk
