Ok so just the other day I scored and picked up a 2.93 LSD for $20, so seeing as I got it so low I thought I'd clean it up and replace the side seals and oil. I was wondering what do you guys use to clean your diff ?(exterior) and what kind of oil is best recommended for the 2.93 lsd ? and how much would I need to buy ? also would you recommend Timken seals ? Thanks ahead !
2.93 lsd swap recommendations
