Catching Low
  • BAlbertiX
    • Apr 2011
    • 258
    Catching Low
    Over the last two years, I've replaced the clutch, throwout bearing, pressure plate and slave cylinder on a '91 ix. Recently (past 3months) and intermittently, the clutch has been catching very low, and the pedal coming up slowly. Feels like the clutch master, but after taking a look, it's not leaking, and the slave has a full hard throw when the clutch master is pressed to the floor. I bled the system twice with a full reservoir. Still same issue.
    My local foreign car garage says pressure plate. Given the PP is only a year old, I'm still thinking clutch master. Before I take it to another shop or start throwing parts at it, has anyone here seen similar symptoms?
    Side note, cold dry days the clutch is fine, rainy/foggy days make this problem much worse.
    Thanks
    '87 325is coupe
    previous:
    '91 325iX coupe
    '86 325e sedan
  • Poorboyz
    • May 2012
    • 2117
    Try checking the 30° plastic elbow that goes into the clutch master from the soft line in the brake reservoir. I had mine break and I still had clutch pressure but it was doing what you described. Mine was also leaking in between the carpet and the firewall.
    #7 on the below RealOEM.com chart
    http://www.realoem.com/bmw/showparts...04&hg=21&fg=10
    Sent from my Galaxy Nexus using Tapatalk
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • BAlbertiX
      • Apr 2011
      • 258
      Thanks Poorboyz, will investigate. Was yours cracked or had the fit between the the elbow and soft line loosened?
      '87 325is coupe
      previous:
      '91 325iX coupe
      '86 325e sedan
      • Poorboyz
        • May 2012
        • 2117
        Mine was cracked 75% around so clutch was still working but every time I used it fluid would leak down the clutch master in between firewall and carpet. And I didnt notice it until clutch completely stopped working. I got the plastic elbow replaced and I got an extra one. It took 3 days to get them.
        • BAlbertiX
          • Apr 2011
          • 258
          Checked the clutch master cylinder's elbow again tonight and it's dry as a bone. Nothing on the carpet or the braided line.
          Maybe, just maybe the garage knew what they were talking about. I'll keep you guys posted with what worked.
          Thanks again poorboyz
          '87 325is coupe
          previous:
          '91 325iX coupe
          '86 325e sedan
          • BAlbertiX
            • Apr 2011
            • 258
            Finally dropped the transmission.
            Found the problem.
            This was only after 50k, highway mileage...
            '87 325is coupe
            previous:
            '91 325iX coupe
            '86 325e sedan
              That would probably be from a bad throw out bearing. Or some restriction in the clutch lines or master cylinder that isn't allowing the bearing to fully release.
