axle nut with subframe out of car?
  • funcrew
    • Jun 2007
    • 1223
    So, I didn't really think this through very well. Subframe removed from wrecked shell. I'm wanting to remove the axle from a loose subframe/TA, and there's obviously nothing to stop the axle from turning. should I run the parking brake cable back into the car and hook up the lever? A six-foot-long vice grip would do it, but I don't have one.
    Any ideas?
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • dirtbag30
    • Apr 2013
    • 678
    put two lug bolts in, get a breaker bar in between them and use it as leverage. if that makes sense.
    or an impact.
    i have no idea what i am doing with my life
    • DIIRTY-30
      • 1665
      Impact + large pipe wrench worked for me... did this a couple times..
      BLUE NOSE - M62 SWAP
      THE E30 + 1 BUILD
        A +600ft-lb 3/4" drive impact wrench will spin the nut right off.
