Does anyone have a list of parts needed to fix the 5th gear lean issue in a zf 5 speed?
5th gear lean
i recommend doing it man, i thought the same thing but it is such an annoying problem. For better or worse im pulling the motor again to do the headgasket and i will do this at the same time.
I just priced out the parts it looks like about 40-80 bucks at most
I bet you could see if your tranny has the problem by attaching the shifter to it outside of the car, spin the output shaft to help it into gear94 325is
I need my car driving in 4 weeks and have a lot of shit to do. I don't have time to wait for parts and tools so I'm gonna have to hope that the trans is good.
If I hook up a shifter and shift into the various gears, what am I looking for to identify if there is a problem? Does the shifter in neutral just sit below 5th instead of the pocket between 3rd and 4th?
we do these on almost every ZF we've laid hands on. the first time i did it on my ZF was scary but every single on thereafter was quick and simple. just take your time. get the proper drift pin!IG: deniso_nsi Leave me feedback here
It will sit under 5th gear, the bigger issue is that you cant tell where 5th gear is because it feels just like 4th, when it gets bad enough its just luck whichever gear you get and i guess it can get even worse to the point you cant get it into 5th
I hear you man, i needed to get mine done asap too and now im pulling the engine again, ha
It wouldnt really bother me if it was just leaning on mine but 4th/5th is in like the same exact spot on mine94 325is
Originally posted by catalyst. View Postwhere did you get the driftOriginally posted by frankie591 View Posthttp://www.bimmerdiffs.com/collectio...ssion-products
No idea if these prices are good or not. 60 bucks for drifts, 70 bucks for the service parts. Any other sources for these drifts?IG: deniso_nsi Leave me feedback here
There was a recall on 5th and reverse detent pins, the poster there might have changed 3rd because it was a problem for them. I think it becomes an issue if its hard to get it in gear.IG: deniso_nsi Leave me feedback here
