Buying Advice for 318i with Suspected Bad Diff
  • Chuckles
    • Mar 2014
    • 9
    Hello,
    I am going to look at a promising 1991 318i on Wednesday that I may get for a reasonably low price because the owner feels the diff is shot. According to him he was driving along when he started to hear clunking/banging noises so he parked the car. I wish I could provide more of a description, but this is all I got. I would appreciate input on the following questions:
    - Do the small case diffs typically fail?
    - Could this be bad rear sub/diff bushings?
    - Any other thing I should look for?
    Right now I am thinking about changing out the diff fluid and seeing if that helps, but it is common for fluid to eventually leak out?
    Thanks,
    Chris
  • ArtClassShank
    • Jul 2013
    • 143
    Does it still drive?
    1989 Carbon Black 328is
    • Chuckles
      • Mar 2014
      • 9
      According to the owner it "should" make the half-hour drive back to my place. I have roadside assistance so I have also debated about getting it towed to my place if it is possible the diff is salvageable. However, I have been searching for a 4.10 LSD as backup.
      I have been seeing conflicting info about small case and medium case diff compatibility. Can anyone viewing also verify whether a medium case diff is a direct swap (1991 M42) without any other parts/hardware?
        That sounds more like a bad drive shaft or half shaft than the differential.
        • cunninglinguist
          • Mar 2004
          • 281
          Check the center support bearing on the driveshaft.
          • Chuckles
            • Mar 2014
            • 9
            My visit got postponed until tomorrow, but I will check the CSB & driveshaft components. Owner appears to be certain it is the diff. Nonetheless, the diff was on my list of updating since LSD > open.
            • ArtClassShank
              • Jul 2013
              • 143
              Well if it is the diff, you can get tons on here for $200 or less.
              • Chuckles
                • Mar 2014
                • 9
                Didn't go for it. Not only was the new paint job (< 1yr) showing rust it was only running on 3-cylinders. These multiple commutes for misrepresented cars are becoming annoying.
                • Dakotademon7
                  • Jan 2014
                  • 446
                  No one ever wants to say there car is a turd. It used to be fun to buy and sell but it's getting to be to much BS anymore. CL is the biggest PITA.
                  sigpichttp://www.germanaudiospecialties.com/
                  1986 325es :early:
