Does anyone know what symptoms I would have if my driveshaft bearing was going bad? I replaced the driveshaft flew plate. I though it was that, but I'm getting a wobble from 20-30 mph and a bad knocking sound in the driveshaft. It's the most annoying thing ever. I've done so much work on this car I just want it to be solid. Please help
Driveshaft bearing?
That sounds like a failure of the rubber mount of the center support bearing, which in turn is caused by binding u-joints in the drive shaft. Replace both with new parts or with a reman drive shaft (I like those from Drive Line Services which come with a new CSB installed).The car makes it possible, but the driver makes it happen.
Originally posted by jlevie View PostThat sounds like a failure of the rubber mount of the center support bearing, which in turn is caused by binding u-joints in the drive shaft. Replace both with new parts or with a reman drive shaft (I like those from Drive Line Services which come with a new CSB installed).
