Vibes
  • B Randon
    • 2569
    Vibes
    Had some bad vibes an a roaring in rear end of car starting at around 75mph, as time went on it got worse an started in a lower speeds (25mph). swaped out diff an the most of the vibes went away.
    checked guibo an found that 1 bolt was missing an another was loose.
    replaced an tightened all bolts down. the csb looked to be good, never took heat shield down just stuck my phone with the video on up in there an looked at it that way.
    i still have some vibes in what i believe to be the drive train but unsure, of what to check next. I can push the clutch in an they go away. Trans is a dogleg.
    po said the rear subframe bushing where going out but i have never had a problem with it but dont rule that out.
