Where to buy ring and pinion gears ?
  • Dakotademon7
    • Jan 2014
    • 446
    I have an 86 325es and can't seem to find a place that sells gears for my car. Would also be interested in a Posi unit rebuild kit for same. I tried Google search .
    sigpichttp://www.germanaudiospecialties.com/
    1986 325es :early:
    I have no idea where you would find those parts as I don't think they were ever available as separate parts. It would make more sense to just get a replacement (used) differential if the ring and pinion need to be replaced.
    • spdracrm3
      • Sep 2009
      • 959
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
      • dustyperez
        • Feb 2012
        • 390
        bimmerdiffs has the stuff or i got my ring gear from ebay.co.uk and it was cheaper to buy and ship then just buy here
        • Dakotademon7
          • Jan 2014
          • 446
          Originally posted by spdracrm3
          SWEET ! Thanks so much.
          1986 325es :early:
          • Poorboyz
            • May 2012
            • 2117
            Is going to be cheaper and a whole easier in the long run to just buy a used diff in the gear you want.
            Rebuilding since 07/06/2016
            Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
            Poorboyz Feedback Thread
            • matthugie
              • Mar 2004
              • 1810
              It depends on the situation. I bought new clutches from bimmerdiffs (the gears were fine) and being in a central racing hub got someone to do the labor on the side for $50. With new gears I was only looking at $5-600 for a completely rebuilt diff, as opposed to $250-$300 for a used diff or 1k+ for a rebuilt unit from someone here. My labor costs were abnormal for sure, but if he can do it himself he can definitely have a good diff for pretty cheap.
              88 325is - S52 powered
              Originally posted by King Arthur
              We'll not risk another frontal assault, that rabbit's dynamite!
              • FLG
                • Sep 2011
                • 3165
                Actually a rebuilt diff from wangan style on here is super reasonable. He built the drift diff in my car but also offers more oe rebuilds.
                Sent from my SCH-I545 using Tapatalk 2
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                • Dakotademon7
                  • Jan 2014
                  • 446
                  I know but then I was thinking about waiting to find the ratio I want for sale,cost of diff,cost of shipping,if I will get ripped off buying one from a member,condition of diff,will it be the correct rear,ect. I may get lucky and find one at a salvage yard. It's not like the yards around here are loaded with them. It may be a little more cost but I'll know my diff is in good working order.
                  1986 325es :early:
                    Understand that if you change the ring or pinion gears that the full set up (shiming) of the differential will have to be done. It would not make much sense to do all of that and not use new bearings.
                    • Dakotademon7
                      • Jan 2014
                      • 446
                      I have a friend at work that does diffs. I'm going to rebuild it gears,bearings and discs. He's going to help me setup the gears. I'm thinking of going with the 40% disc kit.
                      1986 325es :early:
