Clutch isn't fully disengaging?!
    You can fully bleed the clutch by pumping the pedal 80-100 times. I use a pressure bleeder, simply because it is faster and less effort, but pumping the pedal works.
    Assuming the right master and slave are installed and the system fully bled, a disengagement problem will most likely be a worn clutch disk. By a worn pivot pin, a worn throwout bearing, bad pressure plate, or cracked clutch fork are possibilities.
    • ajiiE30
      • Mar 2014
      • 29
      Yup, i bled the system to my best ability. Took it to a shop and they said the clutch pedal was fine. Most likely something worn out in the bell housing. I'm getting the clutch replaced.
