Driveshaft unbalanced
  • ccarlozz
    • Oct 2012
    • 32
    Removed the driveshaft to work on subframe. Reinstalled and now there is a significant vibration. I'm thinking the driveshaft is unbalanced. What end will I need to adjust? The guibo side, at the diff or both? Also how can I tell when it is installed correctly? Trial and error by starting the car each time?
    Thanks.
    There should be a paint mark on each half of the drive shaft at the join. Match the marks and the drive shaft will be in balance.
    • ccarlozz
      • Oct 2012
      • 32
      Thanks so much. I'll give it a try tomorrow. Your posts have been helpful on more than one occasion!
      • DesertBMW
        • Aug 2011
        • 1033
        Thanks.
        What did you do to subframe?
        • ccarlozz
          • Oct 2012
          • 32
          Dropped it to install subframe bushings, rtabs, and springs.
          • DesertBMW
            • Aug 2011
            • 1033
            if you installed heavier duty bushings more vibrations would be transferred to the chassis.
            • ccarlozz
              • Oct 2012
              • 32
              Understood. It actually turned out that the CSB mount was loose. Tightened it up and now there is no more vibration.
              Thanks again.
