Hey guys, the car is a 1986 325e. The clutch wont fully disengage when I try pressing down on the peddle, giving me a hard to put the car into 1st and 2nd. I first thought it was a shot linkage / bushings so I took everything apart and put it back together and no luck. I did some research and people were directing towards the slave / master cylinder. So I replaced the slave and bled all 4 brakes at the same time. Still no luck.
What would I be looking into replacing next? Would I be better off with the a used transmission with low KM's?
